SOLVED - "Failed to update firmware! If device supports WIFI and bluetooth
Discussion in 'Software Solutions' started by nothing movi, Jul 12, 2016.
  1. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    I just solved how to fix this error message while updating firmware(i was updating to akira). It has only been referenced once online and with no solution. ( http://forum.freeflysystems.com/ind...oth-please-reboot-device-and-update-usi.3090/ )
    "Failed to update firmware! If device supports WIFI and bluetooth please reboot device and update using bluetooth"
    This updated failed on 2 androids and 2 mac computers. What I did to solve the issue after lengthy emails back and forth with Chris was to do an unbrick firmware update. So i guess if you have this issue get a hold of them and try to get the instructions for an unbrick+jumper+firmware update
    This ended up working, the firmware update progress bar was moving for the first time and now everything works.
    #1 nothing movi, Jul 12, 2016
  2. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Can you not post the instructions?
  3. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    I've been asked not to share how we got it to work however there is a solution that worked for me that Freefly helped me with.
  4. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Eh! So what is this a test or something. I have the same issues u had and u got help from who ever. Why would it not be helpful to share to others that are having the same issue!?
  5. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    There's a reason. You should just contact them and work through it and hopefully get it sent back.
  6. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    So I have to wait for a response from FF when there is a solution you know about! Maybe a weekend FF warrior will chip in. Don't get why a solution would be with held for any reason.
  7. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
  8. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    Sorry bud. Wish I could help more. But reference my (Yuri Tereshyn m5) problem solving with support to see if they can help you
  9. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    So what they going to do if you help others... BAN you! If its such a secret then delete the thread that says "SOLVED"
  10. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    It's better to say there is a solution than to leave it unknown?
  11. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    Bollocks. Thats what the forum is for to give solutions not give BullPhoo answers that helps no one and just waists time. Don't bother replying unless you can help with a solution the than contact support... Forum = support from others who help each other not play games. Delete the post its useless.
  12. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    Sorry man. It's the best I can suggest. Contact them in reference to the issue which was temporarily solved in my case in a certain way.
  13. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    'Temporarily' Great. again the post is misleading and useless. Have fun with your working M5.
  14. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    I will. It's the one I won for second place in #freeflyanywhere
  15. Dave Halton
    Dave Halton Member
    Sep 14, 2012
    112
    WFD.. Thanks for sharing nowt.
  16. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    Just call support and use my case as a reference.
  17. Andy Johnson-Laird
    Sorry, Dave...I actually don't know the answer -- and, as I'm only a volunteer and don't work at FF I don't have a particular "in" with FF. My best guess -- and it really is a guess -- is that the procedure, if done without specific instructions and/or assistance may result in Really Bad Things happening to the device.
    I will ask FF on your behalf though -- and to confirm whether I'm right on this.
  18. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    Pretty much
  19. Gary Haynes
  20. nothing movi
    nothing movi Member
    Jul 24, 2014
    30
    Conversations cannot be linked? I thought I'm just replying to comments. Maybe I'm just confused by the mobile site. Anyway everything is good and my Akira works :)
