different stand offs for Vibration Dampening?
Discussion in 'Cinestar 8' started by Jason Smoker, Mar 23, 2015.
  1. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    853
    67
    I am just wondering if anybody has tried different stand-off lengths for the Vibration dampening?
    I am doing this because i see props in my shots when doing 360 with my gimbal.
    Anybody tried this? good bad ugly?
    I know that it has more suspension length i am wondering if this will have any problems flying?
  2. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    I do something similar to that, but lower the entire vibration isolator down ... Works a treat for me.
  3. daniel clarke
    daniel clarke Member
    Aug 9, 2012
    49
    i would like to do something similar, my escs are just above my vibration isolators and the heat is making them soft. anyone got a good link to buy different length standoffs?
    cheers.
    10,371
    Hey Chris:
    If you have a moment, could you post an image or two?
  5. Jason Smoker
    Oct 23, 2012
    853
    67
    Steve Maller likes this.
  6. daniel clarke
    Aug 9, 2012
    49
  7. Chris Fox
    Apr 14, 2013
    463
    86
    Hey Guys,
    Sorry for the slow response, here are a couple of shots of the underside of some of the airframes I'm using. I build plates for the ESCs which sit under the main bode, and then lower the vibration isolators below this.
    I use Freefly components for the vibration isolators down, everything else I custom build now. I invested in a CNC router and now produce my own frames.
    There is also an X8 there using gryphon booms ...
    vib isolators flat 8 1.jpg vib isolators flat 8 2.jpg vib isolators X8 1.jpg
    Steve Maller and Jason Smoker like this.
  8. Jason Smoker
    Oct 23, 2012
    853
    67
    is that a custom plate you made Chris?
    how long are the axiel posts you used top and bottom?
  9. Chris Fox
    Apr 14, 2013
    463
    86
    Hey Jason,
    Yep the entire copter is custom made, the stand offs are about 35mm ... that allows enough room for me to get my fat fingers in there to do everything up.
    Cheers
    Chris
    Jason Smoker likes this.
  10. Jason Smoker
    Oct 23, 2012
    853
    67
    Just Wanted to share something I am trying out, I gave a test run in the office seemed to worked ok.
    will report back once i fly it. right now its ready for a crane job coming up
  11. Andy Johnson-Laird
    10,371
    It will be interesting to see if the increased length shifts the center of gravity far enough to cause some "pendulum" or resonance effects -- or whether it improves things.
  12. Jason Smoker
    Oct 23, 2012
    853
    67
    The Question is how low can you go?
  13. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Jason, I wouldn't stretch the standoffs just from the center. It will perform much better if you increase the lenght from the sides. I have increased the standoffs 5cms and it performs no different.
    [​IMG]
  14. Jason Smoker
    Oct 23, 2012
    853
    67
    Okazan just looks like you added super long standoffs from the vibration dampening like in my first photo is that correct? Also looks like the same star plate i bought from aliexpress?
  15. Ozkan Erden
    Aug 3, 2012
    678
    131
  16. Jason Smoker
    Oct 23, 2012
    853
    67
    How long are the stand-offs are you using?
    Where did you buy from?
  17. Andy Johnson-Laird
    10,371
  18. Jason Smoker
    Oct 23, 2012
    853
    67
    Andy I know what they are called cheers. But I just wonder where people buy " There axial posts from".
    I just wonder how much weight you can dangle from them before they snap? And I am sure they are many different companys that make them. Just putting my 2 cents out there
  19. Andy Johnson-Laird
    10,371
    Hi Jason: Apologies....your use of the words standoff made me think you didn't know -- and as we both know if you don't know what something's called, you can't find it on the Internet! :)
    I think the machine screws are more likely to bend before the axial posts do.
  20. Ozkan Erden
    Aug 3, 2012
    678
    131
    Jason, my standoffs are 5cm long and they are custom made. You can find them from ebay though. Link
