Tilt problem on Majestic Mode
Discussion in 'MōVI Pro' started by Bayena Sosa, Jan 25, 2017.
  1. Bayena Sosa
    Bayena Sosa New Member
    Nov 25, 2016
    18
    I'm always getting around -10º of pitch in monitor. Why can be that?
  2. Graham Futerfas
    1,261
    245
    Hi Bayena, Do you mean it's tilting down? Or leaning to the side? There are settings in the App that can adjust these things, but maybe I'm not understanding the problem you're describing. Are you set to Majestic Angle or Smooth Lock?
  3. Bayena Sosa
    Nov 25, 2016
    18
    It's tilting down in Majestic Angle. 10 degrees above the horizon line. I tried every value that involve tilting, and nothing.
  4. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    273
    84
    Possibly its not balanced well, which would also result in bad tuning.. You can check it in balance screen. Good balance would be indicated by values being as close to center as possible in the balance screen.
  5. Bayena Sosa
    Nov 25, 2016
    18
    The balance is good!
  6. Gary Haynes
  7. Karim Belkasemi
    Karim Belkasemi New Member
    Feb 2, 2017
    I have the same problem, how can i fix it?
  8. Henry Schroeder
    Henry Schroeder New Member
    Feb 2, 2017
    10
    Obvious question here but...
    Is this issue with the gimbal mounted on the ring sitting stationary? The feet send it about 10degrees out of level. The gimbal stays level to its GCU on the back. One early morning I had such a brain fart.
  9. Karim Belkasemi
    Feb 2, 2017
    So is an fix to this problem, Is any way I can Trim Tilt?
  10. Henry Schroeder
    Feb 2, 2017
    10
  11. Karim Belkasemi
    Feb 2, 2017
    I'm on set right now, and my camera pointing down all the time, it's all balans, but for some reason tilt 15 digress lower then should be, how can I fix it. Any way I can trim my tilt?
  12. Deniz Ozgoren
    Dec 17, 2015
    273
    84
    You can switch Tilt to Smooth Lock or increase the Majestic Tilt Window. Its normal for tilt to go down about 10 degrees in Majestic mode since the Ring is also tilted..
    Graham Futerfas likes this.
  13. Henry Schroeder
    Feb 2, 2017
    10
    Yes that's why I was saying earlier, its level in relation to the GCU on the back.
    You can try smooth lock to see if the gimbal is not holding level, I had one sent to me with a bad tilt gyro.
    Post a vid of the problem if avail
  14. achenrainer flo
    achenrainer flo New Member
    Jan 10, 2017
    Hi graham could you please do me a favour could you send me perfekt settings in the app that the mimic is running smooth i have massiv problem with the smoothnes
    tryed so much could you just sen d me screen shots of your phone
  15. Graham Futerfas
    1,261
    245
    Hi Achenrainer, what settings are you asking to see, exactly? Dual Op settings? Majestic Settings? Or the settings when I connect to the Mimic with the app?
  16. Graham Futerfas
    1,261
    245
    Here's a video of my Mimic setup and app settings. Hope it helps.
    Samer Aslan likes this.
  17. Bayena Sosa
    Nov 25, 2016
    18
    Sorry, my last name doesn't appear. Can someone from freefly help us with this problem?
  18. Andy Johnson-Laird
    Looks like you took care of it, Bayena (well, presuming your last name is Sosa, that is!)
    Thanks!
