Spektrum Users; Need help mapping velocity and arm enable channels
Discussion in 'ALTA' started by Sean Haverstock, Sep 2, 2015.
  1. Sean Haverstock
    Mar 6, 2013
    64
    Hey everyone,
    I'm looking for help mapping the velocity clamp and arm enable channels. All other channels mapped and working. DX9 port assignments are all equal. Throttle to throttle; aux 1 to aux 1 etc. Channel assignments are (flight mode) Gear - B; (RTH switch) Aux1 - G; (Climb Rate) Aux 2 - RKnb; (Velocity Clamp) Aux 3 - RLv; (Arm Enable) Aux 4 - D
    As I toggle thru the remaining channels (8-12) for velocity and arm enable in the ALTA app I'm unable to get a response with the three position switch D or the right rear slider (RLv) or any of the switches or sliders. Any ideas? Thanks!
    Hmm. Might require an email to FF, Sean. I don't have a DX9 with which to experiment, I'm afraid.
  3. Gary Haynes
    Did you make the configuration changes in the ALTA app and then wait 3 seconds after the change? Was the Configuration Jumper removed when you made the changes? Page 35 in the manual.
  4. Sean Haverstock
    Mar 6, 2013
    64
    Yes to both. I swapped the channel inputs and mapped RLv to climb rate and RKnb to Velocity. Climb rate still works with a different input (RLv) but can't get velocity to respond. Not sure why I can't get the last 2 channels mapped.
  5. Gary Haynes
    Which receiver are you using?
  6. Sean Haverstock
    Mar 6, 2013
    64
    2 x DSMX satellites. Used an AR7010 to bind them one at a time. Could that be why I'm short 2 channels?
    When ALTA is powered both sats are solid orange.
    I'm assuming that there isn't actually a receiver installed just satellites after they've been bound?
  7. Gary Haynes
    That might be the issue. AR7010 is a 7 channel receiver. And once you get them bound you don't need the RX. It's been awhile since I worked with Spektrum. Maybe someone else can chime in that uses them more often. An aside the AR9020 is a 9 channel RX.
  8. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    878
    70
    Sounds like you run out of channels like gary said
  9. Sean Haverstock
    Mar 6, 2013
    64
    Yep. I just got an extra channel after binding with an AR8000. While I know the radio would need all 9 channels, I didn't think that the satellite would be limited to the 7 channels of the receiver since I'm not actually using it. Thanks guys!
