hey, when i use tilt, roll move little bite.. and when i use roll, the pan move little bite too.. its problem with transmiter or its my movi ?(i have a crash with bike... evrithing its okay but i have the small probleme with that.. -i have futaba T8FG ''VPP#1'' SBUS and mode 5 thanks for advence and sorry for my english..
Tholozan: Welcome to the forum. If it's not too much trouble, would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/ Thanks Andy
Brice, the roll trim in the GUI and on the transmitter is to get the Horizon dead level. Example on my setup I need -1.1 degrees of adjustment. Nothing wrong with the system. Adjustment is there so that you can get everything lined up after you have done all of the balance adjustments.
Brice try flying it and see if you get the same reactions. Ground testing is good but you may find that the results in flight are a bit different. I don't see anything wrong at this point. Would also be good to see your settings in the GUI for the various windows gain settings.
yes i have forgert its operateur config : SBUS 5 1 2 3 1 4 ok i will try but before i renember ihavnt this problem.. its maybe gap with systeme or problem with telecommande?
