Hello Andreas, I have been using Red Epic Dragon (not the carbon) with M5 for aerial for a while and it works as long as you put a lightweight lens like Zeiss High Speed PL lenses. I had to change the dual 15mm vertical tilt bars with longer ones to use the full cage. And no Red Volt, I power it with another lipo. Red has narrow profile, so it's easier to balance roll axis. Red Raven is smaller and lighter than regular Dragon. So it should work with less hassle.
If you are asking for Zeiss High Speed MK II / III lenses, all works except 18mm (25-35-50). Other than these, I have tried Zeiss Distagon EF series and these work very well also. (18-25-35-50).
Hi Ozkan, did you use the battery belt for powering the RAVEN as the cage of the M5 might be to small for a V-Mount on camera ? Cheers for feedback & regards, Tomas
Tomas welcome to the forums. Would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/.
