Problem with G-forces on helicopter...
Discussion in 'MōVI M15' started by Asier. Schwarzlose., Apr 3, 2018.
  1. Asier. Schwarzlose.
    Asier. Schwarzlose. New Member
    Feb 22, 2018
    10
    When the helicopter turns to the right or to the left, the ROLL engine in the Mōvi goes to lose the horizon and it takes a long time to return to the correct horizon ... How can I solve it? Somebody has experience with it? I would be glad with your help. Thanks!
  2. Graham Futerfas
    1,213
    238
    Are you handheld inside or fixed mounted to the helicopter?
    What is your Heading Assist set to?
  3. Asier. Schwarzlose.
    Feb 22, 2018
    10
    handheld inside, whats mean "Heading Assist"?
    10,357
    1,161
    Asier -- that's a tough problem to solve entirely, I'm afraid. As Albert Einstein observed, gravity and acceleration are indistinguishable, so when the helicopter turns, it subjects the MoVI to an acceleration and that "fools" the internal motion unit (IMU) into believing that "gravity" is coming from a different direction so the horizon changes.
    Graham: Suggestions to minimize the acceleration error thus induced?
    Chris Harrison likes this.
  5. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    In the expert menu, you can set the "Heading Assist" to "GPS" which helps to fix the horizon, BUT, the MEMS sensors used on consumer type gimbals, including Movi, susceptible against high speed chasing, and fast turns. You will have horizon issue eventually.
    On high end systems, fiber-optic gyros are used. Freefly released for a fiber optic gyro for Movi XL but they are very very expensive and there is no such a solution for Movi series except the XL.
    Asier. Schwarzlose. likes this.
  6. Asier. Schwarzlose.
    Feb 22, 2018
    10
    Thanks bro for the GPS Tip!... I'll try
