Movi MR not stabilising in Airborne mode.
Discussion in 'MōVI MR' started by Ian Whitington, Oct 7, 2013.
  1. Ian Whitington
    Ian Whitington New Member
    Jul 12, 2013
    I just setup my Movi onto a my Skyjib 8. After changing the setting under gimbal application to Airborne mode the Gimbal is not staying level in roll, tilt and pan. The motors are powered up and I have 3 solid green lights but it's not responding to gimbal movement. I don't have my remote controller connected at the moment as I've left it at the my office but just wanted to check if this is normal and if I'm missing something. I'm test flying it tomorrow.
    Thanks,
    Ian
    Ian: I see a distinctly different behavior when I have switched the MōVI to Airborne, but do not have the Transmitter turned on. The gimbal tracks but very lazily...as though the Stiffness values are turned way too low. However, when I turn the Transmitter on, the MōVI changes to a much more normal response.
    I'm tempted to say, therefore, that the problem you're seeing is because of the apparent contradiction between "Airborne Mode" and not have the transmitter turned on. Certainly it would be worth trying your experiment again but with the transmitter turned on when you can.
  3. Adam Paugh
    Adam Paugh Distributor
    323
    78
    Hello Ian,
    Start up sounds normal. Most likely your motor drive is in the "off" position. As Andy mentioned, use the transmitter to switch to dual operator mode
    Greetings,
    Adam
  4. Ian Whitington
    Jul 12, 2013
    Thanks all, it works great with the transmitter on. Going out to test now as I have some rare nice weather here in the UK.
  5. Andy Johnson-Laird
    Glad it worked out for you -- both the equipment and the weather.
  6. Bryan Harvey
    Bryan Harvey Member
    Nov 3, 2012
    227
    18
    Andy I am having the same problem. In airborne mode every axis is "working" and tuned as high as i can get without shuddering, but I get very lazy unacceptable performance in the air. As I don't have my Spektrum transmitter set up yet to control the gimbal, I would still like to better understand the reason behind what you are saying.
    Why might having the transmitter connected make any difference to the gimbal stabilization performance?
  7. Gary Haynes
    Bryan you need the DX7 turned on and switch to either Majestic or Remote Mode when you are in airborne mode. Majestic would be the default but the while the motors are running there is no further control of the gimbal. Also check to see that you have set the GUI to 'Airborne' mode.
  8. Joe Lawry
    Joe Lawry Member
    Sep 9, 2013
    42
    I have yet to figure out the point of the handheld setting in the GUI.. we're just leaving it in Airborne mode 100% of the time either handheld or under the octo..
    When we set up our Futaba remote we were never able to get control over pan when set to hand held mode.. switch to airborne and everything works!
  9. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    HI Joe, In airborne mode the the "majestic" setting on the mode switch locks the pan axis for take off and landing.
    Tabb
  10. Bryan Harvey
    Bryan Harvey Member
    Nov 3, 2012
    227
    18
    Any reason my Spektrum Dx6i would not work for controlling the Movi?
  11. Gary Haynes
    It should work fine.
