M15 won't connect to Nexus
Discussion in 'MōVI M15' started by Scott Jones, Oct 7, 2014.
  1. Scott Jones
    Scott Jones New Member
    Oct 7, 2014
    14
    Hi guys, just got the M15 and having trouble connecting it to my nexus. Downloaded the latest software and still not having any luck! The device is paired with my tablet, i've accepted the pass code etc.. but once i open the app it just won't connect. Anyone have any suggestions or has had the same problem before with m10 or m5?
    Cheers
    Scott
    What actual brand of tablet do you have? Have you turned off any other BT devices that close by?
  3. Scott Jones
    Oct 7, 2014
    14
    Thanks Gary, It's a google nexus 7. works fine on our M10's but for some reason won't connect. I'll try turning off BT devices close by but tbh i don't think there is any other near by anyway.
  4. Gary Haynes
    Scott, send a note to support@freeflysystems.com. With that tablet you should have no issue in connecting. You are running the latest version of the GUI?
  5. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Scott, make sure you have the latest update for the Nexus. Mine was giving me the same issues. The Android had an update for OS, downloaded and it seems to be better so far since update. Keep us posted on what you find please?
    Scott Jones likes this.
  6. Scott Jones
    Oct 7, 2014
    14
    Boom! Jim your a star, the Android update had kicked it into gear. Thanks for your advice :)
  7. Chris mierzwinski
    Apr 29, 2013
    57
    I have a similar issue with my m15. updated my nexus 7 to the latest android. disconnected any nfc wifi signals. I paired the m15 to the blue tooth and can see it on the freefly devices found. but when i try to connect i get the message "Comms revision not recognized"
    any ideas my freefly app is version 1.44 The reason i haven't updated is because my m10 is still running the original firmware. I don't want to upgrade it yet. I wonder if i update the freefly app my m10 will still work?
  8. Gary Haynes
    Chris the GUI needs to be aligned with the app version as I understand it.
  9. Andy Johnson-Laird
    10,366
    That's my understanding too.
  10. Scott Jones
    Oct 7, 2014
    14
    Chris, It has to be updated, Both GUI and Nexus and then it's fine
  11. Chris mierzwinski
    Apr 29, 2013
    57
    Will that break the connection with my m10 that is still on the original shipped firmware? I'm not planning on upgrading the m10.
  12. Scott Jones
    Oct 7, 2014
    14
    You'll need to get an alternative tablet then dude.
  13. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    You can upgrade the app only. Your old M10 firmware will still play nice with the new app as well as the new firmware on the M15. As long as the app is the same or newer than your most advanced firmware version.
    Bryan Edmonds likes this.
  14. Chris mierzwinski
    Apr 29, 2013
    57
    Awesome thanks Brad. That's what I was hoping to hear. :)
