FPV Camera compatibility
Discussion in 'ALTA' started by alex ryan, Oct 21, 2015.
  1. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Hi,
    So I've been having trouble getting the OSD to work with my ALTA.
    The latest update from the support team at FF is that it could be the fpv camera I am using not being compatible with the OSD.
    I am using an RMRC 420N camera. Just wondering if anyone out there is using this fpv camera and if so have you had troubles with the OSD?
    Cheers
  2. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    This also raises the question of how the hell does the OSD work? It gets sent to the camera and then out of the camera to the Tx? why not just send the camera signal to a processor that overlays the OSD and sends to the Tx? It seems that this would be the smarter way to go about it and illuminate most compatibility issues.
  3. Gary Haynes
    Camera sends the video into the Synapse which then overlays the data screens (if the OSD is turned on) then it goes to your transmitter.
    The camera 'might' be an issue. Your 420N is a 400 video line camera. The suggested cameras are typically 700 lines. Could be that the OSD resolution is matched for 700 lines and 400 isn't going to work.
  4. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Just an update guys. I thought if it is a camera compatibility thing then maybe the OSD would work if there was no competing camera signal.
    I unplugged the camera and low and behold, the OSD works!
    Looks like we found the problem!
    Strange thing is with the camera plugged in the video works fine, just the OSD doesn't work.
  5. Andy Johnson-Laird
    10,366
    This matches what I posted on the other thread, Ryan.
    http://forum.freeflysystems.com/index.php?threads/ext-voltage-problem.7139/#post-64976
  6. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Yep looks like thats the problem, thanks for the replies.
