Folding Props
Discussion in 'ALTA' started by Zac Eskelsen, Jun 18, 2015.
  1. Zac Eskelsen
    Zac Eskelsen New Member
    Jun 3, 2014
    26
    In the past I've had issues with folding props and not being able to get out all the vibrations because I wasn't able to balance the props.
    So I guess my question is, how do you balance folding props and minimize those vibrations?
    Mark McGuire likes this.
    10,357
    1,161
    If you use something like a Top Flite or DuBro Tru-Spin prop balancer, do you find that you cannot keep the blades unfolded?
  3. Zac Eskelsen
    Jun 3, 2014
    26
    I use DuBro. but the folding props i've used in the past don't have a hub so its not like you can mount it on the balancer. I've gone as far as making a hub, but if the props fold in or aren't perfectly straight then its not accurate.
    10,357
    1,161
    I suspect we'll need to 3D print some kind of clamp that holds the blades in position -- the ALTA's blades fold in the horizontal plane -- which was your point in the first posting. The 3D clamp would need to pretty precise otherwise it would cause a potential imbalance itself.
  5. Gary Haynes
    Zac I'll go out on a limb and say that the Alto test pilots are not doing any balancing. I've not heard of anyone doing balance on any carbon props and some folks that I respect didn't even balance their wood props and had no vibration issues based on their tuning of the vibration dampers. And those were pre-MoVI.
  6. Zac Eskelsen
    Jun 3, 2014
    26
    Interesting. Its difficult to not want to balance the props. But I suppose if you aren't getting vibrations you shouldn't need to worry about it.
    I've heard that weighing each prop with a precise scale and getting the weights equal was another option.
    any opinion on that?
  7. Aj White
    Aj White Member
    Feb 14, 2014
    82
    I havent bothered with balancing props for about a year, ever since I just started buying quality CF props. I spot check every once in a while but they are almost always perfect. I'm sure FF is doing the homework and wouldn't provide sub-par props on the rig.
    The thing is, we are all so used to tinkering and "fixing" stuff. The whole goal with the ALTA is to change that frame of mind and just plug and fly... focus on creativity!
    Ben Platts likes this.
  8. Janne Hoglund
    Janne Hoglund Member
    Oct 4, 2012
    364
    23
    I balance every prop I use! Even if they only make very little vibrations why not get rid of it by balancing them ;-)
    What I can say is that, most often, the more monney you spend on props the better balanced they are.
    For every Okto of mine i usually get 10-12 props. Of 12 plastic props, 12 always need balancing. With 12 expensive Carbon props usually 2-4 dont need any balancing at all, and the rest need a lot less than the plastic ones.
  9. Angus Benson-Blair
    Jan 23, 2013
    148
    25
    For folding props, get a jeweler's scale and then add weight to the lightest blade at its center of gravity. It's what most people do who fly single rotor helis which use effectively the same thing ie two folding blades.
