Firmware Update Error: SerialNo mismatch - help!
Discussion in 'Radian' started by Louis Wilsher, Aug 29, 2013.
  1. Louis Wilsher
    Louis Wilsher New Member
    Sep 13, 2012
    15
    Hi. My Pan module quit passing the signal to the other modules (but still passes power) so I decided to try and re-install the firmware (currently running 1.03) to see if that fixes the problem.
    I can get into Bootloader mode and read the module in the bootloader software; I can load the firmware 1.03, but when I go to write to the module it does not work. The error message is: SerialNo mismatch.....what do I do?
    10,369
    Mr. Bill: Firstly if it's not too much trouble, would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/
    Secondly could you post a screen image showing the problem, please?
  3. Louis Wilsher
    Sep 13, 2012
    15
  4. Gary Haynes
  5. Louis Wilsher
    Sep 13, 2012
    15
    The new Firmware file worked! Thanks for your help.
    10,369
    By the way, where did you get that image you are using of a person watching me land? ;)
    Steve Maller likes this.
