Hi guys, When trying to connect to the M5 this message appears "Firmware revision not recognized" the message appears on both the Ipad and Iphone both running V1.630 of the app. Anybody have any ideas? Cheers Andrew
Andrew sounds like you may have a mismatch between the firmware on the MoVI and the app version you are running on the iPad/iPhone. Check on the FF main site and make sure you have a 'matched' pair. Current MoVI is 4.02. Also you might try a re-install of the IOS software and or connecting from a laptop.
Andrew, strange to say I had the same problem -- with 4.02 installed some time ago and using 1.630 of the Mac OS X app, I got the same message. I fixed the problem using the MōVI "bootstrap jumper" and re-installing version 4.02. Andy.
