Battery Latch O-ring replacement??
Discussion in 'MōVI M10' started by Justin Marx, Dec 11, 2013.
  1. Justin Marx
    Justin Marx Active Member
    Oct 3, 2013
    326
    26
    How do you do this? O-rings decided to break......
    How to you reattach the o ring bands to the battery latch on the MoVI?
    Thank you :)
  2. Wolfgang Armin
    Wolfgang Armin Active Member
    Sep 20, 2012
    291
    25
    Erm - without having the MoVI in front of me: I´d assume you just lay the latch onto the o-rings, and move one loop through the other.
    Then you do the same with the battery basket - just that you put the latch through the loop instead. I guess you´ve realized by now that english is not my first language :-D.
    Reminds me that I have to carry some rubber bands in my camera bag - just in case.
  3. James Leonzio
    James Leonzio Member
    Sep 3, 2013
    71
    16
    Mine broke also, and I'm embarrassed to admit how long it took me to figure out which way to wrap and stretch the cable and new o-ring. I figured it out eventually, but really have no idea how to describe it. If someone could post a close up picture how it looks when it's secured correctly, that would probably be the most helpful. I'm not near my MoVI at the moment.
  4. Gary Haynes
  5. Justin Marx
    Oct 3, 2013
    326
    26
    Thanks guys! Gary pictures worked like a charm!
  6. Kevin Kelleher
    Kevin Kelleher New Member
    May 5, 2014
    How do you attach the other end to the frame? My bands keep snapping every time I try it.
  7. Gary Haynes
    Remove the screw from the top of the inboard post and slip them over the post.
  8. Lael Camak
    Lael Camak Member
    Sep 9, 2013
    37
    Wolfgang, you did an excellent job of describing it.
    Gary, that is funny. Reminds me of our conversation topic at NAB.
    Having four teenage daughters finally helped. My band snapped and I replaced it with a thick hair rubber-band ... there's always three or four on the floor near the shower. Works beautifully, stretches great, durable, and plentiful at my house.
    All the best,
    lael
  9. Ben Ruffell
    Ben Ruffell Active Member
    Jan 15, 2014
    227
    33
    Mine broke also… only lasted a few shoots.
    Have put in the spare, ordered replacements.
    Hopefully there is a more robust solution for the M15.
  10. Tuukka Ylonen
    Tuukka Ylonen Member
    Feb 19, 2013
    205
    So I suppose this is how the frame end should be mounted?
  11. Andy Johnson-Laird
    10,366
    Tuuka:
    The short answer is yes! :)
  12. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
  13. Keith Colodny
    Keith Colodny Member
    Jun 22, 2013
    32
    Can someone provide a link where we can purchase replacements?
  14. Gary Haynes
  15. Lael Camak
    Lael Camak Member
    Sep 9, 2013
    37
    Walmart has them. Although you have to buy it in a pack of 25. Elastic hair bands. I have used one for 2 yrs now.
