Aero Landing Gear
Discussion in 'ALTA' started by Raymont Stüssi, Nov 11, 2015.
  1. Raymont Stüssi
    Raymont Stüssi New Member
    Dec 12, 2012
    15
    Hi there,
    I flew the Alta yesterday an for the beginning it was very good. Now, i`m setting up the Movi 15. In the box of the landing gear is this Qty 1 - Aluminum Pan Tube Extension which i don`t know how to use this tube? Can anyone explain me what this tube is for?
    Raymont
    Raymont it is used to replace one of the two pan tubes. Purpose is to allow you to mount the landing gear leg and still be able to slide the pan knuckle clamp all the way to the back of the tubes. Basically is is about an inch longer. If most of your setups find the knuckle forward about an inch from the back you can clamp onto one of the regular tubes. I did that since I fly a moderate weight setup.
  3. Raymont Stüssi
    Dec 12, 2012
    15
    Hi Gary,
    I`m not shure if we talk about the same tube?
    It is shorter and has a groove to the outside....
  4. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Raymont, that's for M5 gimbal.
  5. Gary Haynes
    Ozkan got it correctly. Other one is for the M15.
