I have searched around a bit but I am unable to find any wiring diagrams on FPV for a CS8 with MK electronics. I have already setup my downlink setup for the 3 axis gimbal using the mondo stinger. My question is where to pull power for the FPV for the pilot. I have a lawmate 1.2ghz system and ordered a MK OSD. Does anyone out there have examples of this? I want to fly further then my 20/30 vision allows. Thanks for the help in advance.
Josh which OSD did you purchase? If it's the SmartOSD then it can be very straight forward. I don't use the Lawmate so do you know if it passes through power to the camera like an Iftron? If so then Camera -> OSD -> Lawmate. Personally I like to power from a separate Zippy 3S 2500 for the video. I get a cleaner, less noisy signal that way rather than powering from the main batteries.
That's a good idea, Gary. I was wondering whether to attach it to Boom #5 on the C8 to counterbalance the weight of the OSD/Navi/GPS and the FPV cameras on Boom #1. Andy.
I don't get that scientific. Stack on Boom 1 is pretty close to center axis. My iftron is about halfway out on Boom 5, but represents maybe 80g of total weight at most. So that's about 1% of total weight. As much as we would all like to have everything absolutely balanced I probably am always close, at least that's what MKTool shows me, but the batteries never go in exactly the same spot and the copter is moving, tilting, and all the rest. So I do the best I can and then fly the machine. Only reason I put it on the back was it seemed logical. Most of the time we fly away from the base station. So that position just made sense to me keeping the antenna as visible as possible from the base. Beauregard in Steamboat mounts his antenna on a folding vertical mast.
