Turn Bluetooth off?
Discussion in 'MōVI M5' started by Paul Hara, Nov 2, 2017.
  1. Paul Hara
    Paul Hara New Member
    Jan 5, 2017
    I work in an area where bluetooth is not allowed. Is there a way for me to turn it off on the MoVi M5?
    9,678
    1,030
    Hi Paul:
    AFAIK there is no way to turn Bluetooth off.
  3. Paul Hara
    Jan 5, 2017
    Thanks Andy, I was afraid of that!
    9,678
    1,030
    I'm not sure it meets your requirements but you might consider wrapping the control unit in aluminum foil to act as a Faraday screen and block the BT signal.
  5. Paul Hara
    Jan 5, 2017
    I’ll try it and see what happens. If sensors don’t see the signal I’ll be OK. Thanks for the tip!
    9,678
    1,030
    Another thing you might try is copper mesh -- you can get it from Art Supply companies. For example: https://www.dickblick.com/products/...MIr4T8nbut1wIVyIV-Ch05UwCFEAQYAiABEgJmqPD_BwE
    Just make sure that it completely encloses the control unit and antenna. You can fold the edges to form a seal.
  7. Paul Hara
    Jan 5, 2017
    Awesome thanks!
