Does anyone have experience building tethered drones? I need to build one for science center who doesn't want to worry about batteries, or charging.
I don't recall any discussion on the forum about tethered drones, Dave. I think a larger issue (apart from tangling the tether in the props) is the weight of the tether leads to diminishing returns -- the higher you want to fly, the more lift is going to be devoted to just lifting the tether. The next problem I'd worry about is the forces that the tether might exert on the drone -- especially in the wind. Cheers Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limitâ„¢ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
i dont know about building one but ive seen them http://www.unmnd.com/drone-tether-systems.html http://www.ntpdrone.com/ and then theres this guy https://diydrones.com/forum/topics/successful-tethered-flight
Assuming that tetherd is referring to tetherd power to a drone First make a drone non thetherd capable of achieving what all you want to do , if it's for filming or some kind of surveillance Then make sure your craft is stable , and is capable of lifting the weight of the wire you are gonna lift using the craft Make necessary calculation so that you can provide enough current required for the drone via the wire . Continuous uninterrupted power is essential for drone , since the speed of each rotor is responsible for the flight characteristics and the RPM of the motor is depending upon the volatge and current . Make sure your wire is capable of transferring the power to the drone , Make sure you have a back-up battery in the drone .
