after I left go of roll stick on futaba instead of leaving roll where it last was, the roll automatically levels itself. Is there a way to turn this off ?
Hi Michael: I assume that your roll control the factory default left stick moved left/right? If that's the case you can try reducing the spring tension that centers the left stick in the left-right axis. See page 17 of the Futaba 8FG manual, right hand column, Adjustment of stick lever tension. I've never done this, but I think you can reduce the stick tensioning springs so that if you move the left stick to the left, or to the right, it will not re-center. Please post again if that works for you. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
