Movi m5 shakes during the steps
Discussion in 'MōVI M5' started by Łukasz Wójcik, Aug 7, 2017.
  1. Łukasz Wójcik
    Łukasz Wójcik New Member
    Jan 14, 2016
    Hello,
    I film movi m5, sony a6500 and 19mm lens. I try to reduce visible shakes of the steps. Is the one you see in the movie normal? Will any changes in settings help?
    a sample -
    Regards
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    749
    60
    AS the great "Andy Says"
    Do bear in mind that the physics of the MōVI is such that it cannot remove vertical motion (that is, motion along any of the axes) -- it can only remove rotational motion about the pan, tilt and roll axes. So the vertical "bounce" that I see is something that it cannot remove -- that has to done by the operator, I'm afraid.
    The way I learned to walk was with the MōVI was to fill a coffee cup to the brim with water (why waste good coffee?) and then walk with it without spilling any. It caused my neighbors (and their dogs) some considerable concern when they saw me doing it
    Roy Mills and Graham Futerfas like this.
  3. Andy Johnson-Laird
    9,594
    1,018
    Thank ewe, thank ewe, Mr. Smoker! :)
    I call it the Groucho Marx walk...although this is more extreme version of it:
