Hi, i am a bit confused about the accuracy of the motor current data within the app. it shows 20A each motor while hovering (11.5kg). with this i would be able to fly about 9 minutes with 20Ah but i flew 12 minutes and loaded 12000mAh in my 20A batteries. 120A current for hovering 11,5kg is very high. or do i get something wrong? best Rolf
Rolf - the app is reporting Phase current, which accounts for your observations. You can check DC current in the data log and also compare to the estimated capacity in the log as well.
thanks, Tabb! i didn't find DC current in the data viewer when we looked at the data after ESC update. I don't have a PC here in my studio to check again only Macs wherever i look the "real" amp current must be somewhere between 60 and 70A for all motors but i don't want to use a current sensor to check it (for many good reasons ).
Rolf: The Synapse log files are in .csv file format so you can open them up with Excel if you have that on a Mac. Look across the column heading in Row 7, for "Current" (on the log files I have it's column EN). Andy
