Hi there!!! I have a Movi M15 and today I tried to update the firmware but during the process I have turned it off on the switch accidently and now it simply just don't work or respond to anything, I don't even can connect it via wireless or bluetooth with tablet or pc. I believe that it is because the update process was interrupted. Now what can I do to bring it back to life?? Is there a way to connect it via usb to the computer?
Hi Nuno, you can try contacting Freefly at support@freeflysystems.com. You can also look up their knowledge base article about using the five pin jumper cable to put it into boot loader mode and recover it. Good luck.
Hi sando, welcome to the forum. If it's not too much trouble, would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/ Thanks Andy
