Hello, When I connect the radian to the computer, the nick axis is seeing SBUS data whereas I am using PPM. I noticed sometimes when I powerup the Radian, one of the three axis is stabilizing whereas the mode switch of the radio is set to Stabilization Off. Also I am wondering how to change the end points of the nick axis? I would like something narrower. Is it possible to adjust the roll axis (horizon) during flight with a pot on the radiocontrol? Finally, it would be great to setup a home position in order to get the nick axis coming to this position before landing by flipping a switch. Thank you and regards
For changing the end points of the nick axis see FAQ #10. It doesn't narrow it down, but you can limit the amount of tilt up. Andy.
