Alta at High Altitude
Discussion in 'ALTA FAQ' started by Rakesh, Aug 19, 2016.
  1. Rakesh
    Rakesh New Member
    Aug 19, 2016
    Can i fly Alta 8 at 14500ft altitude with red epic and prime lenses temp. Is around 20deg celcius
    9,506
    1,002
    Hi Rakesh, welcome to the forum.
    The flight data in the ALTA 8 manual on page 23 might allow you to extrapolate the data you need.
  3. Dylan Glockler
    Jun 14, 2013
    98
    19
    At that altitude there may be issues with electrical arcing. Electric motors at higher altitudes can experience arcing. Our Learjet requires special high altitude motors and the electric AC motor has to be turned off at higher altitudes.
    All that, of course, is beyond the obvious legal issues. Where do you plan to fly at such an altitude?
  4. Vincent Delmont
    Vincent Delmont New Member
    Nov 13, 2015
  5. Gary Haynes
    5,131
    441
    And which Alta, the 6 or the 8?
  6. Vincent Delmont
    Nov 13, 2015
    Alta 6
  7. Mike Reid
    Mike Reid Member
    Jul 14, 2013
    106
    Hey Vincent, do you remember what your flight time was? Just to be clear from the description, you were flying 4x 4500mah 6s lipo's? I'm flying up in the Atacama next month and was going to take my X8 flying U7's but may pack the alta too after seeing this. Nice one!
  8. Vincent Delmont
    Nov 13, 2015
    Hello mike,
    Hello, yes I flew with 4 x 4500mA / 6S to share in 4 the problems of over-current because the engt snt very solicited. Indeed, at 4000 meters, there is twice less air and therefore half the lift. With the drop in temperatures this reduces the average flight time by 4 in manual mode (do not fly in GPS mode which too much engages the engines for the position holds). I could not make complicated trajectories and I let slip the multirotor. My flight time was 2 minutes 30 to 4300 meters and 3 minutes to 3800 meters on average for a load of 12.6Kg to 13.1Kg. Also check the paschen law for your set-up at these altitudes.
    With the alta 8 the compromise weight / power is better. Theoretically flights should be easier.
    Good Flight :)
