Wifi adapter connection with Mimic/movi receiver
Discussion in 'MōVI M15' started by Thijm le Grand, Feb 11, 2016.
  1. Thijm le Grand
    Jul 12, 2014
    96
    We just received our new m15 mimic set. incl wifi adapter.
    Is it correct that its not possible to connect them at the same time? It seems to use the same connector as the mimic/movi receiver. Can’t find anything in the manuals.
    Does the wifi adapter interfere with other 2.4ghz controllers when in air (Alta)?
    thnx
    Thijm
    Edit: indeed correct. Does not work in combination with mimic/movi controller.
    https://freeflysystems.zendesk.com/...ference-in-functionality-for-the-new-iOS-App-
    Correct they can not be connected at the same time.
  3. Thijm le Grand
    Jul 12, 2014
    96
    Hi Gary, Thnx for responding.
    No problem we will use the above set with android (handheld only).
    Maybe we can use the wifi adapter on our aerial platform. It uses the Spektrum dx8 only.
    Are there any known issues/interferens when using the wifi adapter in combination with Graupner 2.4ghz (CS8) and Spektrum 2.4ghz (Movi) at the same time?
  4. Kevin Binnemans
    Kevin Binnemans New Member
    Nov 13, 2013
    16
    So, Gary, there are no option to connect the wifi adapter to a M15 AND use the Movi Controler ?
    So bad, i want try AKIRA with my iphone, but also can use the MOVI Controler ..
