Video interference with Spektrum Dx7s
Discussion in 'MōVI M10' started by Gorka Rotaeche, May 5, 2014.
  1. Gorka Rotaeche
    Dec 12, 2013
    36
    Hi .
    I have a 2.4 Ghz PAL video sender. I used for ages with the steadicam with great results.
    But when I use it in the Movi with the Spektrum DX7s I get a interference in the image and it is impossible to frame.
    It seems that the Spektrum use the 2.4 ghz frecuency.
    Any idea how to solve this?
    Gorka not sure that there is a solution other than changing the video transmitter to another frequency. The vast majority of RC controllers are on 2.4ghz. There are some that are on other freq but they require longer antennas. If you can change the channel on the the video TX give that a try.
  3. Josh Haywood
    Josh Haywood New Member
    Mar 26, 2014
    15
    Gorka try and put a helical antenna on your video TX/RX, but be carefully if your flying this movi don't run your copter control on 2.4 if that's the case.
  4. Gorka Rotaeche
    Dec 12, 2013
    36
    Thanks Gary. I tried other chanels and the same.
    But if I put the receiver few meters from the Spektrum the interference is almost gone :).
    Which ones are helical antenna?
  5. Josh Haywood
    Mar 26, 2014
    15
  6. Gorka Rotaeche
    Dec 12, 2013
    36
    OK. Thanks Josh.
    What why do you think that those antennas solved the interferance?
