Tool less Pan Knuckle
Discussion in 'MōVI M10' started by Jair Guillen, Aug 4, 2014.
  1. Jair Guillen
    Jair Guillen Member
    Nov 1, 2013
    36
  2. Brett Harrison
    Brett Harrison Active Member
    Apr 7, 2013
    299
    40
    I installed a new one with the old screws fastener, and it's quite easy to do. Just have a look at the fasteners down the pan drop tube (where the computer sits) all you have to do is undo those and replace.
  3. Kurt Wallrath
    Kurt Wallrath Member
    Nov 8, 2013
    135
    21
    If you're planning on upgrading to the M15, you may not want to buy the tool-less pan knuckle piece. From what I've seen, the M15 has 2 parallel tubes running from the pan motor to the vertical tube that holds the MoVI computers (IMU) so I doubt the piece would work on the M15. Also, the M15 already has a tool-less pan adjustment piece on it.
    Knowing when the M15 upgrade will be available would help your decision also...
  4. Rob Drewett
    Rob Drewett Member
    Oct 6, 2013
    36
    21
    Knowing when the M15 upgrade will be available will help everyone!
  5. Eric Ulbrich
    Eric Ulbrich Member
    Aug 16, 2013
    122
    24
    I installed one last week. Its an awesome upgrade. Id buy it, makes balancing much faster!
  6. Jair Guillen
    Jair Guillen Member
    Nov 1, 2013
    36
    Thank you for all your comments guys, but i don´t want to upgrade my M10 soon. I think first, i need to be a master of the M10. After this, i will think about a possible M15 upgrade. But the tool less Pan Knuckle i think is a excellent accesory. I will go for it,
    Regards.
  7. DanDeSilva
    DanDeSilva Member
    Feb 25, 2014
    32
    I installed this the day it became available. It's been obviously fantastic for quick balancing, but has also been good for packing the movi back into it's case..as the foam is a snug fit.. Now it's easier to un-clamp and shuffle into place.
  8. Roger Fosaas
    Roger Fosaas New Member
    Aug 9, 2015
    25
    Hello Freefly :)
    Is this product expired? "Quick release Pan Knuckle for Movi M10"
    Best,
    Roger
  9. Andy Johnson-Laird
    10,381
  10. Roger Fosaas
    Aug 9, 2015
    25
    Thanks Andy, I have ordered from Adorama now :)
    Roger
