Smoothness of Tero footage?
Discussion in 'Freefly Tero' started by jim mundell, May 22, 2015.
  1. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Just putting this out to those who own or have used a Tero. How smooth is the footage? Any choppiness or fast pitched vibrations? Did any stabilization in post needed to be performed?
  2. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Sorry, not sure what happened to the "ness" in the post header. Should have said smoothness. Disappeared when I posted it.
  3. Gary Haynes
    You ness is back....
    Matt Barker likes this.
  4. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Lol. Thank you Sir!
  5. Robert Eder
    Robert Eder New Member
    Dec 10, 2013
    27
    We use the Tero a lot, however we modded it a bit. Even with spike tires on ice I have not seen any micro vibes. I´d say the first second after a rush start is a bit shaky due to the soft dampeners first compressing then releasing.
    Greetings,
    Robert
  6. jim mundell
    jim mundell Member
    Jan 15, 2014
    240
    15
    Thanks Robert. Was wondering more about movement over bumps. Say over pavers or semi rough surfaces. Do you see anything show up in your footage? What settings are you using on the Movi when on the Tero? Bigger windows, higher numbers on stabilization?
