Can I fly single pilot in majestic mode and yaw aircraft for smooth panning but have tilt control set to a knob on my radio controller?
Qualified yes. I use the Handheld mode, drop the pan window down to a value of 1 or 2 so it stays within a narrow window and then use handheld Majestic which still gives you tilt. If you mount to the standard CS star plate you will find that forward is pointed between booms 1 and 2 (22.5 degree offset to the right). Bit of a pain but you can get used to it. Hoping that in one of the future software updates there is a pan offset control but in the meantime practice with it or have a custom plate cut.
