Hello, I have a problem with the Radian or my RC. I turn on the RC Graupner Mx 12 then connect the battery Gimbal, and immediately the green LED on the Radian of Tilt and Roll turns on and the yellow LED turns off. The LED green and yellow of the Pan Radian keeps flashing. The Gimbal is stabilized but does not respond to the command of the Radio. Can you help me with that please. Thank you.
Alberto on the Radian page there is a sticky with a form to fill out. We need that as a first step. Copy and paste into a response.
Aircraft Type: Cinestar 8 Gimbal Type: 3 axis Radian Type 3 axis Gimbal Power source: 3S Gimbal Radio Type: Graupner MX12 Radian Communication Protocol: PPM Connections: Pan Sensor: Port 1. GR-12 receiver and power. 2. 3. To Roll sensor 4. To Pan Servo Roll Sensor: Port 1. To Pan Sensor 2. 3. To Tilt Sensor 4. To Roll Servo Tilt Sensor: Port 1. To Roll Sensor 2. 3. 4. To Tilt Servo Symptoms: I turn on the RC Graupner Mx 12 then connect the battery Gimbal, and immediately turn ON the green LED of the Tilt and Roll Radian and the turn off yellow LED. The green and yellow LED of the Pan Radian keeps flashing. The Gimbal is stabilized but does not respond to the command of the Radio. Can you help me with that please. Thank you.
