Hello everyone! I just wondered how to get the pan bar alignment right? When i switch the M10 on, the top handle bar and pan axis bar do not align. Even if i fix it with the remote, it will slowly drift off again. The settings on the remote are set to 0 (middle) on the roll, tilt and pan trim buttons, so it isnt the remote asking the M10 do drift on the left automatically. Anyone experienced this before?
This is probably a balance issue with the pan bar. Make sure you watch the videos on how to adjust the pan knuckle. It's a tricky one.
Veve, welcome to the forum. If it's not too much trouble, would you be kind enough to change your user name to your real first name and last name, please? The reasons for this (and how to do it) are explained here: http://forum.freeflysystems.com/index.php?threads/real-names.497/ Thanks Andy
Thanks Justin, I tried and didn't seem to make a difference Not sure what is happening here... Andy lol this is my actual name. Veve borimov is a russian name! The previous one (Gucci) wasn't Would you have any tips on how to get the pan bar fixed in the middle? Thanks for your help guys!
Hi Veve, does this only happen when the remote is on? 0 on the remote doesn´t automatically mean that it´s really centered - thats´why there are trim buttons. I had radios that were way off. Did you try to adjust the trim to the other side?
Veve: Thanks for changing your user name -- it was showing just as Veve, but I can see that you've now, indeed, changed it to your first and last name. большое спасибо за это. Regarding the pan being off-center, Wolfgang's suggestion is good. Check the trim levers -- or post an image of the "home" display screen on the DX7s/8 transmitter please. It will show the settings of the trims. Thanks Andy
If the remote is not causing the issue, also do realize that if your pan window is large, it won't correct if it's within that window, meaning you could be panned 5 degrees left, and it your pan window is set to 10, it won't correct until you move the pan bar 1 degree to the right. It still knows where it's "home" position is, but because of settings it won't move yet.
