I notice the shape of the MK8 is different than the shape of the CS8 the MK8 fits in a square and the CS8 fits in a circle = MK uses 4 shorter length booms than the other 4 booms, CS all booms are the same length is this right? any one care to comment on the + or - of this configurations ? thanks
Smaller props on the MK8. MK Octo XL is 12" props vs 14" props on the CS8. More lift on the CS8. Standard CS8 is 450mm booms. MK is a mix of 460mm and 355mm.
Correct but regardless of the size of props you can put on either frame, my curiosity goes more towards the fact they 4 booms are shorter placing the motors and props in a different position in relation to each other comparing the CS8 all around shape each motor has an identical motor/prop next to it I was wondering if MK design has technical flight reasons to be this way?
