Guys what you think about this??? Its new antivibration system plus quick release system.. it seems great.. its by Kopterworx..!
Any time I see the term "quick release" in regards to something for a copter, I get a little nervous.
Some guys in my multirotor club made a sky jib with that rig a few months ago. Looks interesting, but it also looks complicated and heavy compared to Tabb's rubber donuts.
Pavlos you can see more about this system at Allied Drones. I noticed that they no longer list the Live Wire anti-vibration system but here's a couple of photos.
Hmmm nice.. i havenot seen these systems?? what you think are they good???! THis one seems nice too.. http://www.allieddrones.com/products/echo-anti-vibration-quick-release
Same company. Haven't seen any flight reports on either model. With lots of anecdotal postings indicating that the heavy loads are causing the current FF vibration system to move around to much, the wire system 'looks' like it would be worse. And the new addition using the rubber shock absorbers looks 'better'. If someone is flying these let us know.
I use a similar system in teory but much simpler and not so looking good. It consits in dji antivibration rubers the same they use ,mounted with pressure from the top to bottom like interlaced C looking at each other on a a horizontal position... Does it make sense?
Hi Guys, I have played with wire rope isolators a lot in the past (back in my helicopter days especially) I found they worked OK for some frequencies of vibration but certainly were no where near as effective as silicon isolation system which completely kills all vibration from getting into the gimbal. That said a multi rotor can be made to run smooth enough that you do not even need isolation.....I personally am unwilling to spend the time and effort it takes to keep my machine running at that level though. Running without an isolation system is also stressful since any small problem (chipped prop, bent motor shaft etc) can completely kill the footage and you will not be aware until you are back at the hotel reviewing the days footage. Tabb
