Hi I have a 3 axis CS gimbal w 3 Radiants, this are control by a Spectrum DX8 and satellite for the camera Op, and I am using a MX-20 with a GR-24 for the pilot, no problems here now I would like control the Radian with a 2nd receiver I have GR-12 I have Bind it to the MX-20 and started the mapping using bind 2, this may basic, but I get all confuse on the following steps to assign the channels to the MX-20 switches etc.. I would like to turn on the radiants and to control tilt so when I am a solo pilot/cam op, I understand that I don't want pan on this set up, Josh from Birsd Eye Prod has a cool video talking about it but no datails on the mapping can someone guide me a little thanks
HI JLO: You might want to open up a conversation with Josh directly. Find one of his posts and click on his name (where you see JLO in your posts), and select Start Conversation. Andy.
Hey JLO, I am hoping to have the editing done on the video for this tonight.. Maybe tomorrow... But I am working on it. Post your questions here though and I will help you out. Josh
Hi Josh I have a question its is probably basic but is keeping me from continuing the set up on the gimbal, for the understanding of the "channel assignment" on the second receiver so far I have "bind 1" and "bind 2" done, and I have assign on "control adjust" the switches "SW 3" AND "CTRL7" to inputs 7 and 8 from here I am lost I am trying to understand page 70 and 71 from the manual but hit a wall thats where I am now Thanks
Are you talking about the inputs on the Radian software? You need to make sure that your slew channel for both your Cam Op and your MX20 are the same. Example would be if you have your cam op's controller on (DX8) and he is controlling his tilt using channel 4 then you have to reassign your CTRL 7 Poti to be channel 4. To do this you can use the TX Channel Assignment menu. As you do this you need to make sure you go back and re-assign your controls in MK Tools to make sure you don't have anything overlapping (such as the Poti controlling your nick or roll). Josh
Hi Josh. Thanks for that, I'm trying to do the same thing as JLO but with a futaba. You don't know by any chance if you can re-sign your fc control on the DJI wookong M assistant do you? THanks again. Katya
