Hello everyone i have no spent alot off time with my cs 8 and mx20graupner ,but one day a was in the air with cs 8 ,i heard on my ears a pip and pip and pip ,i looked down on my radio to see what it was and on the lcd screen i just see the GRAUPNER LOGO!!!!! i manage to get the cs lower and then all went normal again,but what was that!!!!! i had the controll over the cs all the time,i felt like it when i came at lower higth the lcd comes back to normal telemetri agin!!!! I was about 70-80 meter higth so not so long away Anyone that have seen something like that? her is my gpx file and if anyone would look at it a will be glad
I don't see anything abnormal on the aircraft side. The anomaly rests with the controller. Maybe Andy has some insights Shaun
It sounds like a temporary loss of telemetry signal Kjetil. I've had that happen too. As to what caused it? It's hard to say. Andy
ok thanks andy it can sound like what you said,i dont lose the controll off the cs,thats good do i have to do something on my mx 20 to activate the failsaft setup for mk or just hook off in the mk tool for failsafe? i am not sure about this failsafe!! thanks
Kjetil: Presuming you are using the MK FC and Navi boards, I would make very certain that: 1. You have set the Come Home altitude to something reasonable for where you are flying (eg. 25 meters). 2. On the Misc window, you have set the Emergency-Gas to, say 90 or 95, and checked the "Use vario control" -- this turns the Emergency-Gas to a percentage. The FC board will automatically determine what throttle setting the copter needs to hover, and then descend at Emergency Gas % of that.... 3. Also on the Misc window, set the Failsafe CH Time to 60 seconds. 4. Remember to write the settings back to the FC board! You can read all about the Emergency Come Home here: http://www.mikrokopter.de/ucwiki/en/FailSafe Andy.
