Movi V-Lock Adapter 25mm or 30mm?
Discussion in 'MōVI Pro' started by Steven Deneault, Jun 2, 2018.
  1. Steven Deneault
    Steven Deneault New Member
    May 24, 2018
    25
    I've got a movi pro and was wondering about the V-lock adapter. In the write up in the accessory section, it says "25mm clamps allow for versatile mounting options". I was wondering how this applies to the movi pro's 30mm ring? Is there another accessory required to mount to the larger ring, or is there a way to mount the v-lock adapter to the ring with the provided materials?
    Thanks.
    Steve
  2. Rorick Edge
    Rorick Edge Active Member
    May 11, 2018
    452
    81
    Hi,
    You’re in the wrong part of the forum. Go down a section and you’ll find the forum for the Movi Pro.
  3. Andy Johnson-Laird
    10,369
    You're quite right, Rorick. I've moved this thread to the Movi Pro forum.
  4. Graham Futerfas
    1,227
    239
    That battery plate was originally made for the Movi M-series gimbals (M5/10/15), which use 25mm Carbon Fiber Handle bar rod.
    I'm sure you could make an adapter with any V-lock plate and an Impact Atom Clamp, and it would go on the Movi Pro Ring. You could also mount the 25mm V-Lock plate onto the Top Handle of the Movi Pro Ring -- the top handle is 25mm and not 30mm.
    I'm curious, though: why do you need a V-Lock battery on your rig? What are you powering with it that you can't power through the Movi Pro's D-Tap outputs?
  5. Steven Deneault
    May 24, 2018
    25
    Thanks very much for the response Graham, good tips. I've noticed you help a lot of people out.
    And you're curious about the right things. I'm in fact going to be powering the Movi/camera/accessories with the ignite digi TB50's, but I always like to have an alternate source just in case and this seemed like an option worth pursuing.
    Thanks again and sorry for posting in the wrong section. I'm new!
    Steve Deneault.
  6. Graham Futerfas
    1,227
    239
    If you get the Ignite TB50 battery adapters, get the ones with the Lemo plug, and you can run a cable down to the cage for follow focus. I think they also have a cable Ignite Digi sells for this purpose. That would cover you for most circumstances.
    The best "alternate" battery source I've used is my old LiPo's from the Movi M15 with a D-Tap adapter. They're light, can be bongo-tied anywhere, and not that expensive. I use them for follow focus MDR's a lot.
  7. Steven Deneault
    May 24, 2018
    25
    I got the Lemo option. Seemed like the only way to go. Thanks again for the tips.
  8. Steven Deneault
    May 24, 2018
    25
  9. Robert MCgregor
    Robert MCgregor New Member
    Jan 13, 2014
    Hi all,
    does the V'lock battery system allow for powering the gimbal as well as accessories? would love to just have lots opf V'locks as all my other things are powered by them. otherwise i'll go for tghe Ignite system for my Pro and M15.
    Also does anyone know if there is an accessory out there to use V'locks on the XL as well?
    Rob
