movi pro + mimic issue
Discussion in 'MōVI Pro' started by hyeongjun kim, Jan 18, 2017.
  1. hyeongjun kim
    hyeongjun kim New Member
    Jan 18, 2017
    There is no shaking in the majestic pan and tilt mode when there is a connection with the movi pro mimic, and there are many shakes in the other modes
    I have tested with other Movi pro, and we have the same symptoms in two mimics, and the other movi pro work fine with two mimics.
  2. Graham Futerfas
    1,261
    243
    If you move the Mimic farther away from the Movi, does it still act like this? The radio signal is very strong in the Mimic, and it can overload the Movi if it's too close.
  3. hyeongjun kim
    Jan 18, 2017
    It's the same symptom as far away.
  4. Jan Schuberth
    Jan Schuberth New Member
    Sep 8, 2013
    i have that same issue
  5. achenrainer flo
    achenrainer flo New Member
    Jan 10, 2017
    i have the sam issue no binding to the mimic
  6. Ryan Forte
    Ryan Forte Member
    Oct 5, 2015
    69
    Having the same problem if someone could weigh in on this would help a lot!
  7. Andy Johnson-Laird
    I suspect one/all of you might have to email to support@freeflysystems.com on this, I'm afraid. Please post again once you get a response and/or workaround.
    Cheers
  8. Daniel Díaz
    Daniel Díaz New Member
    Jul 19, 2015
    11
    Same problem here, I've sent a email to Freefly Support.
  9. Tim Sessler
    Tim Sessler Active Member
    Aug 12, 2013
    185
    65
    Has anybody found a fix for this yet?
    The only way my MIMIC works if I set it to Majestic Pan/Tilt but in Direct it does the same crazy jiggle.
    Hope to find an answer soon :)
    Kishore likes this.
  10. Graham Futerfas
    1,261
    243
    I noticed, with mine, that the Mimic causes this freakout more when it's handheld, but if I mount it to a tripod with a pan and tilt head, it's very smooth. I typically keep the Mimic in 'Level Roll' mode, except for recently when the DP wanted to do a dutch roll, and it worked really well in 'Direct' mode.
  11. Tim Sessler
    Aug 12, 2013
    185
    65
    For my tests I just had it sitting on the floor. That should be comparable to having it on a tripod. I really dont get it. With the prototype that had to shoot THE LIGHT it worked 100%. Never had a single issue. Very odd...
  12. Ivan Robles Mendoza
    Ivan Robles Mendoza New Member
    Feb 11, 2017
    23
    Same problem here
  13. Ivan Robles Mendoza
    Feb 11, 2017
    23
    My first production day with the mōvi pro is aproaching (friday) and i think i wouldn't be able to use mimic due this crazy jiggling. Does anyone found a solution?
  14. Ivan Robles Mendoza
    Feb 11, 2017
    23
    Hey Tim, did you find a solution for the jiggling?
  15. Ivan Robles Mendoza
    Feb 11, 2017
    23
    Hey Kim
    Do you found a solution mean while?
  16. Joshua Coté
    Joshua Coté Member
    Nov 3, 2016
    37
    10
    This has been my entire experience with the MIMIC since buying the MōVI Pro in November. I haven't had any luck with varying distances, channels, or settings. The new firmware hasn't helped either.
    Will send a message to support.
    Ryan Forte likes this.
  17. Tom Gibbons
    Tom Gibbons New Member
    Jan 27, 2017
    Hi there,
    I've been having the exact same issue..has anyone found a solution?
  18. James Layton ACO
    James Layton ACO New Member
    Aug 1, 2015
    20
    I'm having this issue with the mimic, too. Has anyone found a solution? We start a feature film on Friday and the mimic is a key part. MASSIVE issue here...
  19. Graham Futerfas
    1,261
    243
    Hi James, have you tried removing the antenna from the Mimic? Or moving it farther away from the Movi? That's usually the first cause, is the radio is so strong it 'swamps' the signal if they're too close.
    Also, I put the Mimic on a tripod, as I find the sensitivity to cause some vibrations.
    I never heard from anyone on here if there was an actual issue solved by Freefly support or not, but you could try contacting them at Support@FreeflySystems.com Maybe there were defective copies of the Mimic system out there? I've seen several threads on here about it, but no one ever posted their resolution.
  20. Ivan Robles Mendoza
    Feb 11, 2017
    23
    I had to return my gimbal and also my mimic to mövi to be tested and repired. That was the option free fly gave to me.
    Sorry to carry the bad news
