Movi M5 with Graupner receivers
Discussion in 'MōVI M5' started by Ben Burger, Jul 28, 2015.
  1. Ben Burger
    Ben Burger New Member
    Jul 21, 2015
    17
    Hi everybody!
    Can someone please confirm that Firmware v4.01 allows the use of Graupner receivers (e.g. GR-16) on the M5?
    Using PPM you should be fine.
    Rick Chen likes this.
  3. Ben Burger
    Jul 21, 2015
    17
    Thanks, Gary!
  4. Patrick Vollmers
    Patrick Vollmers New Member
    Mar 17, 2014
    Hey Guys,
    did one of you test it? I have a MX-16 with a GR-12L and i don't bring it to live with my M5...
  5. Gary Haynes
  6. Patrick Vollmers
    Mar 17, 2014
    Ok, done! Are you also able to answer my question? ;)
  7. Gary Haynes
    Sorry Patrick I don't run Graupner equipment since leaving the MK stuff behind. Perhaps Ben can give an update.
  8. Patrick Vollmers
    Mar 17, 2014
    Hey guys,
    i also had problems because i tried to use my MX-16 with a GR-12L.
    Here is the solution that worked for me and the reason for my problem:
    Graupner has its own philosophy of ppm or sum-signal. There are 3 different version of their sum-signal called SUMO (sum-signal-out, analog), SUMI (sum-signal-in, analog) and SUMD (sum-signal, digital). The only one that gives a analog ppm signal is SUMO. The receiver „GR-12L" doesn’t have the ability to send SUMO (analog) but can send SUMD (digital).
    I took another receiver (the Graupner „GR-16“) wich is able to send SUMO-signal and it worked out direct. The mapping-settings you wrote depend on the pre-settings you make in your transmitter (what action goes to wich channel…).
    Everything works out perfectly an with the new Akira-Firmware it got a weapon...
    It also discused here: http://forum.freeflysystems.com/index.php?threads/graupner-firmware-3-08.4968/#post-66832
