Movi M5 on DJI S1000 - power using BEC
Discussion in 'MōVI M5' started by sandeep nandy, Nov 14, 2015.
  1. sandeep nandy
    sandeep nandy Member
    Nov 5, 2015
    44
    Hi,
    Getting my movi next week which will be installed under S1000 using Kopterworx mount. I seen the M5 battery are 4S LIPO. In order to save the Lipo weight, can i use 24V to 12V voltage converter and power the movi using 12V input ? This way, i need to use only my LiPo for multicopter to power all equipments.
  2. Angus Benson-Blair
    Jan 23, 2013
    150
    25
    I wouldn't bother as this will stop you being able to fully pan the Movi. The Movi 5's battery is pretty lightweight anyway and would only shorten a flight by a few seconds. With that said what you are suggesting could be done although you dont want to drop to 12v, more like 15-16v
    sandeep nandy likes this.
  3. Steve Maller
    3,979
    No.
    10,376
    +1 for what Steve said. :)
  5. sandeep nandy
    Nov 5, 2015
    44
    I would like Steve to elaborate :)
    10,376
    I can do that too. The MōVI cannot operate correctly on 12 volts. :)
    A 4S Lipo, at maximum voltage it is ~16.8 volts and the minimum useful voltage is ~14.0 volts. You'll find that that at 12 volts, the MōVI is pretty useless.
    On the other hand, if you could provide, say, 15 volt power that should work.
  7. Steve Maller
    3,979
    Thing #1: The MōVI M5 runs on 4S (16V) not 3S (12V).
    Thing #2: It's very complicated to get power down from a copter to a MōVI in a way that allows 360° movement. It can be done using a slip ring or other such silliness, but again, "why"?
    Thing #3: The M5 batteries weigh very little. Trying to eliminate them is false economy.
  8. sandeep nandy
    Nov 5, 2015
    44
    Thanks for clarifying.. all good now .
