Movi M5 and Red Epic Dragon
Discussion in 'MōVI M5' started by Ozkan Erden, Oct 9, 2014.
  1. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    A picture is worth thousands of words.
  2. Drew Kachurak
    Drew Kachurak Member
    Aug 9, 2013
    188
    23
    No issues with this set up?? Seems like weight far exceeds the M5 capabilities. Can you share more of your setup and its performance?
  3. Pete Maughan
    Pete Maughan Member
    Mar 1, 2014
    75
    11
    Hi Ozkan,
    Is that the carbon dragon?
    Pete
  4. Ozkan Erden
    Aug 3, 2012
    678
    131
    Yes that's carbon dragon.
    The setup is limited to several lenses + you need supply power from a lipo. It can be only used for MR stuff. No room for any accessories.
    The heaviest suitable lens I could find was Zeiss Super Speed T1.3 25mm. Zeiss EF Distagon series are also good to go.
    No issues for balancing roll and pan. Tilt balancing is a bit tricky but not the hardest as long as you place the lipo on the right place.
    The results I get is very satisfying, I will post some footage soon.
  5. Drew Kachurak
    Aug 9, 2013
    188
    23
    No go on the hand-held stuff? Can you post some additional pictures of your set up please?
  6. Ozkan Erden
    Aug 3, 2012
    678
    131
    No way on for the hand-held unless you are not using a follow focus + a heavy prime lens.
  7. Derek Cooper
    Derek Cooper Active Member
    Apr 28, 2014
    527
    34
    More photos please? Interesting.
    How's the stability in flight? No "wobbles," as the motors try to catch up?
  8. Ozkan Erden
    Aug 3, 2012
    678
    131
    This is the only two photo I have.
    There is no problem regarding the motor hold performance nor wobbling. It just flies beautiful.
  9. Derek Cooper
    Apr 28, 2014
    527
    34
    Intriguing...
  10. Jason Herring
    Jason Herring Member
    Apr 7, 2013
    278
    What bird is that?
  11. Ozkan Erden
    Aug 3, 2012
    678
    131
    That's a Cinestar 8 frame with Kde 4014XF-380 KV motors, using 18" props. The FC is Mikrokopter FC 2.5.
  12. Jason Herring
    Apr 7, 2013
    278
    Thanks for all the info, what flight time are you getting?
  13. Ozkan Erden
    Aug 3, 2012
    678
    131
    I get around 7 minutes with single 10A 6S battery. 4014XF motors are very power efficient with 18" props.
