Mimic´s battery
Discussion in 'MōVI Pro' started by sebastian navarro, Dec 13, 2017.
  1. sebastian navarro
    sebastian navarro New Member
    Mar 6, 2017
    11
    Hi! I just wondering if is normal that the mimic´s internal battery dies if left unused for a week. Actually it won't turn on until I plug it to the usb. I don't use the mimic regularity so I don´t know if is normal or not that the battery discharge from 100% to 0% in less than a week.
    greetings
    sebastian
    10,356
    1,161
    I've noticed the same behavior, Sebastian. I don't know whether I'd go so far as to call it normal -- but I infer it's a combination of the battery's internal self-discharge or perhaps some chips in the MIMIC are causing a current drain. Pure speculation on my part, though.
    Cheers
    Graham Futerfas likes this.
  3. Graham Futerfas
    1,213
    237
    There's supposedly a 'handshake' of buttons you can press on the Mimic that enables a Travel mode, and supposedly keeps it from turning on accidentally. I'm not sure if this mode also prevents the battery drain, but it's not a well-advertised feature, and I can't remember which buttons to press to enable it. Maybe Bryan or Deniz can post about it?
    10,356
    1,161
  5. Matija Petrovic
    Matija Petrovic New Member
    Nov 20, 2013
    19
    Same problem here, battery drains in one night from full to empty :(
  6. Andrea Cecchini
    Mar 19, 2014
    33
    The same happen to me regularly. The battery is a SHAME!
  7. Graham Futerfas
    1,213
    237
    One solution I have is to mount a cheap USB battery to the side of the Mimic with dual lock velcro, and I have a short little USB to USB-C cable to keep it neat.
    I like USB batteries with a push-button indicator and 4 LED's that show how full the charge is, and they sell on Amazon for like $12. Two or three of those batteries will keep your Mimic running around the clock.
  8. Andy Johnson-Laird
    10,356
    1,161
    Yeah...I use the same little battery -- but the MIMIC does have an internal self-discharge it would seem.
    Cheers
  9. sebastian navarro
    Mar 6, 2017
    11
    Hi! I just tested the mimic´s battery enabling the shipping mode and store it for a week( Pressing all function button while powering off the mimic. To reactivate it you have to connect the usb cable to any usb charger and turn it on). Now I have powered the mimic and the battery is at 96%. So is better to leave the mimic in shipping mode if you are going to store it.
    Greetings
    sebastian
