M5 no start up after 3 green LED's
Discussion in 'MōVI M5' started by Kevin Riley, Nov 8, 2016.
  1. Kevin Riley
    Kevin Riley New Member
    Jul 23, 2016
    14
    M5 showing no signs of life after 3 green LED's for 2 seconds. Tried fresh batteries. Checked cables. Looking for pointers.
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    849
    67
    i think a cable has come loose somewhere. try taking of the inspection covers and a see what you find?
  3. Kevin Riley
    Jul 23, 2016
    14
    Thanks Jason - tried this but no go
  4. Jason Smoker
    Oct 23, 2012
    849
    67
    If i couldnt find any split cables or broken ones then. MY last resort would be to find a battery that i knew was good and tested it or send a email to http://freeflysystems.com/contact and see what they say
  5. Kevin Riley
    Jul 23, 2016
    14
    Thanks Jason, I have 4 batteries - all fairly new and fully charged and used a volt checker. Yes - I am having ongoing e-mails with freefly support - wish I had better news but the sun is setting on this day - thats probably the best I could hope for.
    10,371
    Kevin: Was the MoVI just hanging limp like it had not received any configuration settings, or were the motors energized and simply not stabilizing?
  7. Kevin Riley
    Jul 23, 2016
    14
    The rig was just limp with no energy to the motors at all
  8. Andy Johnson-Laird
    10,371
    Hmm. I know this sounds strange but that's what happens right after a firmware upgrade (just as an example), before you do an autotune. If you can communicate with it via the App. it might be worth trying an autotune. I presume you've checked that you controller's kill switch is off? (Sorry for such obvious suggestions -- I don't mean to imply lack of diligence on your part, it's more bafflement on mine!)
    ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone ExperT
  9. Kevin Riley
    Jul 23, 2016
    14
    No firmware upgrade involved. Just a battery change between takes. Also no controller involved - just Majestic Mode. Have undertaken all steps as requested by Freefly and am now awaiting return details.
  10. Andy Johnson-Laird
    10,371
    Understood. I realize you didn't actually do a firmware upgrade -- but the behavior you're reporting sounds identical. I infer that doing a Autotune either isn't feasible or that it didn't fix the issue, right?
  11. Kevin Riley
    Jul 23, 2016
    14
    Correct - Autotune was not possible.
  12. Justin albert
    Justin albert New Member
    Dec 4, 2016
    Anyone clear this up? I'm basically having an identical issue.
  13. Andy Johnson-Laird
    10,371
    Hi Justin:
    I presume you've read through the postings above and therefore haven't just done a firmware upgrade and have checked on the cables, then it "email to Freefly time," I'm afraid. support@freeflysystems.com.
