Hello, I just purchased a Movi M5 (refurb) from freefly store. Balnced camera no problem. Did auto tune and wrote settings to app. When i pick up the movi, i can feel and hear the motors working. Is this normal ? Thank you Kenny
Yes, it's normal. You can manually reduce your motor stiffness in the app on whichever axis is humming, or you can also increase the Filter on those axes. That should help. AutoTune will get you close, but you always should check things with a manual tuning in the app as well. I've also seen AutoTune be wildly off on occasion, probably because something got bumped or jostled during the process.
Also, to add to what Graham wrote, remember to "tune it as you use it" -- so hold it the way you plan to use it when you're autotuning -- if you have it in the stand it has different resonant frequencies from those when you hold it. Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Thank you for the help That is one thing i found myself a bit confused on was, do i auto tune on stand(?), then tune to hand ? Or do i actually hold the movi while performing auto tune. I will do an auto tune holding the movi and see how that goes. Thanks again
It may help to understand that autotune "waggles" the MoVI, sensing the resonant frequencies of the gimbal, and adjusting the stiffness values based on what it senses -- it's pretty subtle so you cannot really see or hear the waggling going on -- but obviously given what it's doing any changes to those resonant frequencies fool the autotune into getting it wrong. Hope that helps Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
