MōVI Pro Goes Insane with MIMIC Connected
Discussion in 'MōVI Pro' started by Joshua Coté, Jan 3, 2017.
  1. Joshua Coté
    Joshua Coté Member
    Nov 3, 2016
    37
    10
    Hey guys,
    So I'm having a lot of problems with the MIMIC. It binds with the MōVI Pro, but once I turn it from "OFF" or "KILL" to "MIMIC" the MōVI starts losing its mind and twitching around wildly.
    Any suggestions on where to start with this? This problem began from the first day out of the box.
  2. Josh Lambeth
    1,315
    216
    Make sure you are at least 5ft away from the MoVI. Mine does the same but once i get some distance between the Mimic and MoVI it fixes it.
    Josh
  3. Andy Johnson-Laird
    Interesting point, Josh. Sounds like the Mimic's transmitter is swamping the MoVI Pro's receiver thus enabling "insane mode"?
    Bryan Edmonds likes this.
  4. Josh Lambeth
    1,315
    216
    Yup! I do believe that is what is happening.
    Josh
  5. Tim Sessler
    Tim Sessler Active Member
    Aug 12, 2013
    185
    65
    Having the same issue - even from 10-15ft away. With the prototype I only had the issue when I was a few feet from it - 4-5ft separation and it worked just fine. Will let you know when I am able to solve this...
    Cheers!
    Tim
  6. Oleg Solodchenko
    Oleg Solodchenko New Member
    Nov 20, 2016
    I had that also but once I went into the app, Dual Op, Adjustments and play around with the mimic mode. Once I took it off 'direct' it seemed to start to perform propertly.
    Let me know if that helps.
    Rob Ruscher likes this.
  7. Olli Koivula
    Olli Koivula New Member
    Jan 25, 2017
    If you're in a tight space don't use the antenna on the mimic. The antenna adds to insanity.
  8. Ryan Forte
    Ryan Forte Member
    Oct 5, 2015
    69
    I sent a support ticket about this to freefly and have yet to hear anything back! I'm gonna try out there gamepad controller and if that works I will stick with that until they figure it out.
  9. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Here is the test for this.
    Put the antenna ON, and go 15ft away. If everything is OK, then you are good to go, just don't get too close to MoVI Pro WITH antenna installed on MIMIC (I remove mine for bench testing)
    If you have problems at 15 FT WITH antenna installed, there MIGHT be something wrong with your unit.
    The new v1.1 beta FW also has signal strength indicators.
  10. Andy Johnson-Laird
    Olli: the conventional wisdom is that removing an antenna from a transmitter is likely to alter the so-called Standing Wave Ratio to the point where so much reflected radio frequency power is reflected back into the transmitter because of the mis-match of the impedance presented to the transmitter, that it burns out the so-called final stage amplifier. See e.g. https://en.wikipedia.org/wiki/Standing_wave_ratio#Practical_implications_of_SWR
    I would therefore really hesitate to operate a transmitter without its antenna given the risk of turning the transmitter into a brick.
  11. Simon Shohet csc
    Simon Shohet csc New Member
    Jan 24, 2017
    Same problems when my Movi is bound to the mimic. I tested my mimic with another movi and it worked fine. I then tested another mimic with my movi and had the same jittery result. Poor signal strength with both mimics on my unit while both are perfect on the other. I have sent videos to tech support, awaiting response. I think maybe the internal Movi antenna is the issue, not the external mimic antenna, but just a guess.
    Ryan Forte likes this.
  12. Ivan Robles Mendoza
    Ivan Robles Mendoza New Member
    Feb 11, 2017
    23
    Mine goes also insane.
  13. Thomas Nakasone
    Thomas Nakasone New Member
    Oct 13, 2015
    Insanity mode as well...tried all of the above suggested tactics...
    anyone ever hear from FF on this? I too submitted a ticket but still have yet to get a response.
  14. Ivan Robles Mendoza
    Feb 11, 2017
    23
    Sorry to hear that, i sent my mimic back to be checked. Did not have the posibility to test it with the latest firmware. Did you tried that? Let me know if it worked for you
  15. Thomas Nakasone
    Oct 13, 2015
    no joy on new firmware
  16. Ivan Robles Mendoza
    Feb 11, 2017
    23
    Today they send me an email...
    They have to call my movi back:(
