How to power my "Nyrius Aries pro" wireless video transmitter with my MoviM5 battery
Discussion in 'MōVI M5' started by Akpe Ododoru, Mar 11, 2016.
  1. Akpe Ododoru
    Akpe Ododoru Member
    Feb 14, 2015
    32
    Am looking to power my "Nyrius Aries pro" wireless video transmitter with my MoviM5 battery
    Can someone pls tell me or link me to the cable i need to get for it?
    Can you also ple instruct or link me to any video that can help with showing me how to connect it.
    The "Nyrius Aries pro" wireless video transmitter is 5v if that helps
    Akpe when I have needed a small usb power cable I have had to make my own. Take a cable that fits, cut it and wire to the appropriate battery/connector. I don't think you will find something commercially available.
  3. Graham Futerfas
    1,213
    237
    Hi Akpe, can you just use an external USB battery to power it? Something like this:
    http://www.amazon.com/iXCC-3400mAH-Power-Bank-Portable/dp/B0128FACBQ/
    Otherwise you're going to need a cable (and a JST splitter, to power your Movi and the transmitter) that has a 5V voltage regulator on it.
    B&H sells a cable like that, but it goes from P-Tap. I suppose you could change the P-Tap connector to JST, but it's a lot of cable to clean up and will cost much more.
    http://www.bhphotovideo.com/c/produ..._tools_indi_gpcc_power_converter_ptap_to.html
  4. Walter Brokx
    Walter Brokx New Member
    Feb 23, 2016
    27
    Just remember that when you completely drain a M5 LiPo it might never charge again.
    When powering the MoVI there is a safety catch to shut the MoVI down before the battery is dead.
    Graham Futerfas likes this.
  5. Akpe Ododoru
    Akpe Ododoru Member
    Feb 14, 2015
    32
    Thanks guys, i might just go with the portable battery Graham recommended
  6. Nicolas Teeuwen
    Jan 15, 2014
    162
    23
    I have done the portable Anker batteries. its not as ideal because it adds weight but it works. If you are using SmallHD monitors, they do 5v out of the USB port, so you can just connect a usb cable (with the right ends) up to the Aries. It will require the small end (i can't remember the name) on both sides.
