How $7.00 almost cost me my bird!
Discussion in 'Cinestar 8' started by Chris Babiana, Oct 2, 2013.
  1. Chris Babiana
    Chris Babiana Member
    Nov 8, 2012
    183
    15
    Brand new from QC, first time used inflight. Running dual QC 8000mAh.
    Thanks to the "MAN" upstairs, I changed my plans and didn't take her out over the ocean today! Luck was on my side for sure!
  2. Steve Maller
    3,979
  3. Tyler Olson
    Tyler Olson Member
    Apr 28, 2013
    154
    wow. not exactly what you want to see
  4. Scott Strimple
    Mar 14, 2013
    99
    Yikes I was just getting ready order one... Thx for sharing
  5. Adam Paugh
    Adam Paugh Distributor
    323
    78
    Hello Chris,
    I will send your posted pictures over to the manufacturer of that parallel connector. This equipment malfunction is completely unacceptable.
    I'd like to send you a replacement part if you confidence isn't totally shattered.
    Greetings,
    Adam
    MIke Magee likes this.
  6. Chris Babiana
    Nov 8, 2012
    183
    15
    Hi Adam,
    Even though not acceptable, I understand these things do happen from time to time. Thanks for replying to this post and taking the time to bring this up with the manufacturer. This will now be one more item on my pre-flight checklist! ;)
    I have great confidence in FF and QC and will definitely take you upon your offer for a replacement part. If you need my shipping info, let me know. You should have it on file at QC.
    Regards,
    Chris.
  7. MIke Magee
    MIke Magee Active Member
    422
    103
    Man. Chris. I'd need a change of clothes for sure. What happened? When did it fail?
    -M
  8. Steve Maller
    3,979
    After something Andy discovered on one of my LiPos I sent him, part of my pre-flight is to give a good tug on each of the EC5 connectors both before and after each flight (in case something had gotten soft from heat). I yanked one of my EC5s clean off a battery before I flew once. Bad soldering job (mine). :eek:
  9. Chris Babiana
    Nov 8, 2012
    183
    15
    Good advice Steve...it's now on my list! Lesson learned!
    Hey Mike.
    She flew fine, no issues. I grabbed the ends on the parallel adapter after landing and noticed they were all pretty warm...weird. That's when it came out in my hand...and I proceeded to experience a shooting pain in my left arm and chest! ;)
    Let get together soon for beers and flying...not necessarily in that order! New England colors must be just about peaking at your end. I wouldn't mind taking a road trip north for the day.
  10. MIke Magee
    422
    103
    Sounds like a plan Chris. Maybe next weekend? A friend wants me to fly his new black magic pocket cam up there for the foliage. Lets touch base next week.
    Chris Babiana likes this.
  11. Nathan Reim
    Nathan Reim Member
    Oct 20, 2012
    112
    That is why I make my own. I know they are done right.
  12. Tim Joy
    Tim Joy Active Member
    Aug 2, 2012
    405
    72
    Scary stuff! Glad it worked out.
    It makes a good case for having dual connectors to the distro board like the latest FF motor control set. Maybe it's not feasible on the MK gear?
    Nathan Reim likes this.
  13. Nathan Reim
    Nathan Reim Member
    Oct 20, 2012
    112
    Good question Tim, wonder if we can do this with the MK pwr distro board, anyone know?
  14. Andy Johnson-Laird
    10,369
    Nathan: There's really no provision on the MK Power Distribution Board to have dual LiPo connections other than by make a Y-connector, the single part of which would be soldered to the PDB. Not sure it gives you the redundancy that you're looking for as the Y-connector and the connections to the PDB will still be a single point of possible failure.
    Steve Maller likes this.
  15. Nathan Reim
    Nathan Reim Member
    Oct 20, 2012
    112
    Yeah I didn't think their was a way, I haven't had any failures so far using my y harness but it seems like if their is goin to be a problem on the copter it's the little parts like that, that make it crash.
  16. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,711
    311
    Andy if the new flight control board is capable of 6S batteries and they are upgrading the BL's maybe they will put out a better design PDB? Just wishful thinking.
  17. Gary McCready
    Gary McCready Active Member
    Oct 26, 2012
    284
    42
    I had the same exact thing happen, twice. Once with my Naza Quad with XT60s and then the Cinestar with the 5.5mm bullets. The wire came off as I unplugged. I really have no one to blame except myself though. I have notice that the solder wicks up the wire, and that was where the break occurred. They really didn't come un-soldered. Both connectors still had wire attached. After using XT60, 4mm bullets, and lastly 5.5mm bullets I decided to really do some home work.
    There is a local outfit that makes wiring harnesses for fighter planes. A friend of mine works there and I asked him what they used. He said they use "crimp type" fittings on everything, and also use adhesive silicone on alot of them. They have hydraulic presses for the big wires. He also said they also only use crimps the space shuttle.
    So I switch everything over to Anderson Powerpole connectors. (except some very small birds: JST) They are easy to crimp, just like servo cables, and I feel much more confident about my connections. Just have to make sure the ends are crimped parallel as possible, as they don't turn in the fitting, like bullets.
    http://forum.heliguy.com/posting,mode,topicreview,t,65102.html
    Colin Snow likes this.
  18. Scott Stemm
    Scott Stemm Member
    Apr 10, 2013
    140
    Gary are you using the 45 amp powerpoles or higher for the battery connection?
  19. Gary McCready
    Oct 26, 2012
    284
    42
    Yes, I use the 45amp for 8 and 10 gauge, 30amp for 12 and 14, and 15amp for 14 to 16 gauge. The 8 gauge is a tight fit, but my strippers cut a few of the strands even in the 8 gauge slot, and make it an easier fit. I don't have any batteries that are 6 gauge or bigger. The 45amp APP can handle 100 amps with no problem, so I'm told.
  20. Scott Stemm
    Scott Stemm Member
    Apr 10, 2013
    140
