When working in doors we cannot get GPS. What are the problems we are going to encounter and is there a signal booster we could use? Also in remote mode can the operation of pan and tilt be put on separate joysticks?
Giles you won't have any problems. I've never hear of a GPS signal booster, at least not at the civilian level. You can remap the sticks in the MōVI app. But if you put one over on the left stick which is now controlling the speed of pan (and tilt if linked) you will have at least one stick that needs to do speed and pan. Can't do it with tilt since the the movement of speed is up and down. So pan and speed on one stick and tilt on the other. Whether left or right for each can all be done in the app by changing the channel mappings.
