GPS Help
Discussion in 'Cinestar 6' started by Tony Larkin, Jun 22, 2013.
  1. Tony Larkin
    Tony Larkin Member
    May 17, 2013
    29
    Hi Guys,
    I'm keen to try MK GPS modes and feel confident about how to use them. However, i'm not confident about how to exit a GPS mode/s? Stick position/ gas???????
    What's the deal?
    Tony
    UK
    Tony if you are in PH with the GPS just turn it off and be prepared to fly the copter. If it is a windy day then you may need to be agressive on the initial stick movement. Gas doesn't affect PH. If you have AH turned on with practice you will know where the hover point of your copter is. On mine I use the center stick spring setup. I know that when I turn off AH that I need to increase gas slightly since my hover point is just above center.
  3. Tony Larkin
    Tony Larkin Member
    May 17, 2013
    29
    Thanks Gary, That makes sense and now i've heard it from yourself i'm ready to give it a try. Weather here in NW England is rubbish today! I'll see what tomorrow brings and hopefully get some flying time then.
    Thanks,
    Tony
