Gimbal Techniques
Discussion in 'Movi Technical' started by Darell Sison, Apr 23, 2019.
  1. Darell Sison
    Darell Sison Member
    Apr 12, 2019
    35
    Hello, looking for some tips and guides on proper techniques on using the MCR. Newbie here so please be gentle with me.
    When doing your moves/shots do you use your arm to turn/pan or you use the gimbal response/movement?
    Any other tips for smoother moves?
    Re: moves: I find I use a bit of both techniques. You learn to anticipate what the MCR is going to do.
    As for smother moves: Walk in a low crouch like Groucho Marx -- practice with a cup of water full to the brim. The MCR only removes motion around an axis, but not along the axis.
    Darell Sison likes this.
  3. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    There are many videos showing gimbal techniques like “the ninja walk” and many others on YouTube. If you search for it, you will definitely find something that is relevant to your filmmaking style and desired effects. Actually FF has a bunch as well.
  4. John Chu
    John Chu Active Member
    May 12, 2018
    106
    47
    My tips and thoughts:
    Decide if you want the Movi to be fast and precise or slow and gradual. (or somewhere in between) I've been running it with a slower response time and wider window to smooth things out outdoors and my bad operating technique. (Along with adding stabilization in editing)
    Hard footsteps and jolts that get transmitted to the rig can cause nasty rolling shutter distortions in the footage.
    Feel liberated and free to hold and grasp the Movi one handed not only by the handle but also on the base or however it feels comfortable.
    If I'm trying to do a lateral shot follow- filming people walking along across the street as I kind of pace them, I hold the MCR by the palm of my hand on the base (with the unit in FREEZE mode). I can continue walking forward normally, while the iPhone is looking sideways.
  5. James Croisdale
    James Croisdale New Member
    Apr 26, 2019
    13
    I have done a day's shooting with a narrow window and fast response at 30fps only to realise that a lot of the footage is faar to choppy. Going forwards, even for action stuff I would tend to have a wider window and medium response.
  6. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    What shutter speed did you use?
  7. James Croisdale
    Apr 26, 2019
    13
    Ah, well that's the thing. Using the MOVI app I didn't really have any control over it as I had no ND filter attached, so yes, it would have been pretty fast, so not ideal.
  8. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    That is why so many of us rejoiced when the Filmic Pro got integrated with the MCR. If you use just the Majestic mode, it is very useful and gives you almost all the control of the video you want. I hope it is working on Android as well, I don't know. I also don't know what the android beta does, I do have couple of Android phones so I should try. Anyway, the latest beta on the iPhone allows you to set the shutter at 50% of the frame period ideal to give you more smear and less jitter.
    #8 Pavel Houda, Apr 28, 2019
  9. James Croisdale
    Apr 26, 2019
    13
    From what I have read here today, I really need to be looking at Filmic Pro... I only every really need Majestic mode, but to have full control of frame rate, bitrate and ISO etc seems invaluable. I was using OpenCamera until I got the mcr, but then it seemed simpler to go with the Movi app.
  10. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    One of the features I like is the "log" and "flat" capture. It'll give you some extra dynamic range. They also provide you with LUTs. Costs $15 though. On iOS the basic version is free, on Android it was asking for $15 right away.
  11. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    273
    84
    You can play with the shutter angle in the new beta release for this at gomovi.com/beta . Cheers
  12. Pavel Houda
    Pavel Houda Member
    Jan 15, 2019
    75
    25
    Deniz, is that true for Android beta as well?
    #12 Pavel Houda, May 1, 2019
  13. Deniz Ozgoren
    Dec 17, 2015
    273
    84
    Unfortunately not.. After spending the second half of 2018 on Android, the team is back to development on iOS.
  14. Stephen Hart
    Stephen Hart Active Member
    Apr 24, 2019
    109
    44
    For an extra $10, you can also get Filmic Remote.
    We're talking about a small fraction of the cost of the Movi CR and an iPhone Xs. I spent more than Filmic Pro + Filmic Remote on a couple of SMALLRIG Ballhead Super Clamps. And with Filmic Remote you get remote control from another iPhone, for example in SmartPod mode.
    Pavel Houda likes this.
  15. Stephen Hart
    Apr 24, 2019
    109
    44
    "You can also see it up to control it with those little "Volume Up" Bluetooth devices. Very well supported indeed.
    Thanks for the reminder. I got one of those free along with a phone tripod mount.
