Gimbal snagging a bit
Discussion in '2 Axis Gimbal' started by Steve Maller, Jan 24, 2013.
  1. Steve Maller
    3,979
    I'm rebalancing my 2-axis gimbal based on what I've learned here, and what I see is part of the gimbal is gently rubbing on another part in the tilt direction. These views are of the left side (the side with the Radian) viewed from behind. It needs another 1mm or so of clearance. What should I do? I never noticed this before. Thanks!
  2. Ben Hall
    Ben Hall New Member
    Jan 20, 2013
    19
    surley that can be easy adjusted out by just loosening a few clamps on the tilt tube and the clamps on the pot and pivot on other side
  3. Marty Ferris
    Marty Ferris New Member
    Sep 30, 2012
    23
    I noticed the same thing when I was setting up my gimbal. You have to loosen the set screw on the tilt wheel pull the rod out a couple of mil and then re-tighten the set screw. I hope you understand my meaning.:)
  4. Mitch Firchau
    Mitch Firchau New Member
    Jul 26, 2012
    10
    loosen the tilt bars where the potentiometer shaft is, then slide the carbon clamp pieces that are inside the regular clamps along the potentiometer shaft until you have enough clearance.
    Hope this helps,
    larry
  5. Steve Maller
    3,979
    Wow, thanks, guys! Very helpful. Worked like a champ. Bummer it started raining just as I finished though. :(
  6. Gary Haynes
    Steve, add all of the above together and basically you need to loosen both sides and slide the bar over. Also make sure that your tilt arm bars are aligned (the ones that hold the tilt bar). If they are out alignment you will get a bit of binding with the tilt bar.
    Brad Meier likes this.
